Power Supply Clarification and help
Kazzam
Full Member level 1
Full Member level 1
A power supply ususally consists of , Filter --> Rectifier --> Power Switching --> Rectifier filter -->Detection circuit.
can someone describe these modules in brief with the function of individual components involved in each module.
That description only applies to SMPS, it is quite different in linear supplies. however, I think this is what you are needing:
1. Filter
This is an EMI filter and possibly a surge supressor. SMPS tend to produce sharp edged signals which are rich in harmonics and could conduct down the power cord, using it like an antenna, and cause interference to radio, TV and other sensitive equipment. The filter is there to reduce the interference down to an acceptable level.
2. Rectifier
Most SMPS use a DC supply to the switching stage, this first rectifier would be at the line frequency (usually 50 or 60Hz) to convert the incomng line AC to DC.
3. Power Switching
Would be the part of the circuit that chops the DC at high frequency, making it look more like AC again. By using a higher frequency than the incoming line, the physical size of the transformer beomes much smaller. This is why SMPS are smaller and lighter weight than conventional supplies. The construction of the transformer determines the voltage the PSU produces.
4. The high frequency pulses from the transformer need to be converted back to usable DC again. That is the job of the second rectifiers. They are usually Schottky or fast switching diodes because normal types are not suitable at high frequencies.
5. Detection circuit
I assume this to mean the feedback circuit. A power supply would normally be expected to give a regulated output. Under heavy loads the output would tend to drop because of the strain and losses in the earlier stages so the output is compared to a fixed regulated voltage and the difference (called the error voltage) is fed back to the switching stage to make it 'push harder'.
I've been very generic in those explanations, there are many types of power supply and they all work in slightly different ways.
Brian.
smps_design_guide
This may help you?
wbr
  • smps_design_guide.pdf
Reactions: Kazzam
    Kazzam
I read your post its controls will provide ISS3 power supplies in quantities controlled by the company's manufacturing capability. Most companies in increase production of power supply, but shortages may occur due to high demand or those for which no alternate power supply or alternate product is available.
Thanking You
Riello-ups
Reactions: Kazzam
    Kazzam
Filter: Reduce electrical noise from power lines.
Rectifier: Convert AC to high voltage DC.
Power Switching: Switches the high voltage DC on/off with high frequency. Thus you can use smaller signal transformer.
Rectifier filter: Smoothen the rectifier output.
Detection circuit: Feedback and control for the output. Thus, regulates the power switching.
Reactions: Kazzam
    Kazzam
Thank you all.
