[SOLVED] Take RTC time from SIM900 via SMS
garagedog
Newbie level 5
Newbie level 5
Previously I wanted to update sim900 RTC via network time [ and I thank again all of you helped me in this forum,
Now I'm trying to add RTC time stamp to the SMS so that I can include the time the SMS was sent, so it will be a big help if anybody could let me know how to properly store receiving UART data to a string using mikroC.
Thank you.
Hi, I tried with "AT+CCLK?" , but where I fail is storing the uart response to a string.
Before you use "AT+CCLK?" command you have to use "AT+CLTS=1" for only once.
This command will enable the module to remember the setting forever and each time the module reboots, module will send ACK to basestation to get timestamp at the beginning and the basestation will return the correct package.
After this use the command AT+CCLK? and capture the data as said earlier by Mr Jayanth..
Hi, sorry it took me days to reply, here is my code:
void main()
unsigned char output[20];
TRISB.LATB0 = 0; //make PORTB pin 0 output
PORTB.LATB0 = 1;
Delay_ms(1000);
PORTB.LATB0 = 0;
Delay_ms(15000);
UART1_Init(9600); // initialize UART1
Delay_ms(100);
UART1_Write_text("ATE1\r\n");
Delay_ms(5000);
UART1_Write_text("AT+CCLK?\r\n");
if (UART1_Data_Ready() == 1)
{ // if data is received
UART1_Read_Text(output, "+2", 10); // reads text until +2 is found
Delay_ms(500);
UART1_Write_text("AT+CMGF=1\r\n");
Delay_ms(500);
UART1_Write_Text("AT+CMGS=\"0737071248\"\r\n");
Delay_ms(500);
UART1_Write_Text(output);
UART1_Write_text("\r\n");
UART1_Write(0x1A);
Delay_ms(5000);
this works fine in proteus simulation with data I enter through virtual terminal, but it doesn't work when I program it to my pic. I also tried the UART interrupt examples but what I cannot figure out is how to enable a UART interrupt only when I send "AT+CCLK?" to gsm module. I'm really messed up with the problem hope you could help me.
Thanks.
Before sending AT+CCLK?\r enable UART receive interrupt using
Code C - [expand]
RCIE_bit = 1; INTCON = 0xC0;
. Three sec after sending the command use
Code C - [expand]
RCIE_bit = 0;
to disable the interrupt.
Edit: It took me 10 minutes to write a working code. Contact me at internetuser2k11(at)gmail(dot)com
Test the attached .hex file. It is compiled for PIC18F452 at 8 MHz external OSC and 9600 bps baudrate.
  • Get Time.rar
I have also tried the same i have not to sent message of that time reading rather right now i want it to display om LCD but not getting proper data
Lot of thanks for your guidance mr. jayanth.devarayanadurga, I made it :)
Thanks a lot for your information.Now I can get the updated time from the Modem.
