[SOLVED] CRC module :- bad synchronous description
ajrox
Newbie level 6
Newbie level 6
entity crc_v4 is
    Port ( clk,crc_send,busy : in std_logic; --crc_send is signal to give o/p
	        b_cnt_in : in integer range 0 to 256;  --byte count of modbus frame
			  b_cnt_rqs,crc_done,read : out std_logic;--b_cnt_rqs is used to indicate to other module for byte count
           data_in : in std_logic_vector(7 downto 0);
           data_out : out std_logic_vector(7 downto 0));
end crc_v4;
architecture Behavioral of crc_v4 is
signal out_cnt : BIT := '0'; --to indicate sending of 2 bytes to output
signal newframe : BIT := '0'; --used to indicate a newframe 0-new 1-old frame
signal byte_count : integer range 0 to 256; -- stores byte count of the frame
type state_type is (s1,s2,s3,s4,s5,s6,s7);
signal state :	state_type := s1;
begin
 process(clk)
 variable data : std_logic_vector(7 downto 0); --to store present byte
 variable count : integer range 0 to 7:=0;--to count the shifts
 variable CRC : std_logic_vector(15 downto 0) :=x"FFFF";--to store CRC value
 variable new_byte : BIT :='0';
 variable done : BIT :='0';  -- used to indicate that processing on 1 byte has been done
 begin
  case state is
   when s1=>
		if(busy = '0') then
		  b_cnt_rqs <='1';
		  newframe <= '1';
		  CRC := x"FFFF";
		  crc_done <='0';
		  state <= s2;
		 else
		  state <= s1;
		 end if;
   when s2=>
     if(busy='0') then
		 byte_count <= b_cnt_in;
		 b_cnt_rqs <= '0';
		 state <= s2;
	  else
	    state <= s3;
	  end if;
	when s3 =>
	  if(byte_count =0) then
	    state <= s6;
	  else
	    if(busy ='0') then
		   read <='1';
			state <= s4;
		 else
		   state <= s3;
		 end if;
	  end if;
	 when s4 =>
		 if(busy='0') then
		   data := data_in;
			read <='0';
			byte_count <= byte_count-1;
			new_byte :='1';
			done := '0';
			CRC(15 downto 8) := CRC(15 downto 8);
			CRC := CRC(7 downto 0) xor data;
			state <= s5;
		 else
		   state <= s4;
		 end if;
	 when s5 =>
	 if(clk='1' and clk'event) then
     if(count < 7) then
	    state <= s5;
	    CRC := '0' & CRC(15 downto 1);
		 if(CRC(0) = '1') then
	    CRC := CRC xor x"A001";
	    end if;
		 count := count+1;
	  elsif(count = 7) then
	    end if;
		 done :='1';
		 count := 0;
		 new_byte := '0';
		 state <= s3;
	  end if;
	end if;
	when s6 =>
	 crc_done <='1';
	 if(crc_send ='1') then
	   state <= s7;
	 else
	   state <=s6;
	 end if;
	when s7 =>
	 crc_done <= '0';
	     if(out_cnt ='0') then
		    data_out <= CRC(7 downto 0);
			 out_cnt <= '1';
			 state <= s7;
		  else
		    data_out <= CRC(15 downto 8);
			 out_cnt <= '0';
		  	 newframe <= '0';
			 state <= s1;
		  end if;
       end if;
	when others =>
	   state <= s1;
	end case;
  end process;
end Behavioral;
I'm designing a crc module for a modbus chip,the code given above
It is a state machine based design in vhdl.
It requests byte count of the current frame from other module and calculates crc.
on command from some other module (crc_send) it outputs the crc.
i'm getting a bad synchronous description error :- Signal CRC cannot be synthesized, bad synchronous description.
plz help.
All the code should be inside the the clocked part of the process. You cannot have a clock in the middle of a process.
process(clk, reset)
begin
  if reset = '1' then
    --async resets go here
  if rising_edge(clk) then
    --all other code goes here
  end if;
end process;
Reactions: ajrox
    ajrox
Thanx TrickyDicky!!
it worked!
