Hi, I've searched this forum but can't find the answer I'm looking for (though, it probably is here, but I'm not technical enough to understand it).
Is there a simple formula for calculating the turns ratio for a 300ohm-to-75ohm balun wound on a toroid form?
Honestly, I can't understand the numerous formulae I've seen here and via Google searches.
I intend to use either 24 or 28 AWG wire as this is what I have on hand.
My intention is to use these baluns on a homebrew 8-bay antenna, and want to make sure the two 4-bay sections are phased properly prior to mounting, as it will be in a very difficult place to access repeatedly.
Thanks in advance!
