ngen33r
Newbie level 6
I am working on reproducing this hobby circuit from zapstudio.com. I wanted to make it surface mount and add some features that I need. I have one of these kits and it works, but the opamps are obsolete and I wanted to make some changes. I rolled a new PCB and it works but the opamps get screaming hot. I measured the outputs with a scope and I am getting some 200KHz-300KHz oscillations with very low amplitude in the output riding on the sine wave. The original design used some film caps, I used all ceramic and the original L272 opamps are not available so I used TI N5532A opamps. Any ideas how to make this run cooler like the original? I have attached both the original and my schematic for reference. If it would help I can also get some screen grabs of the scope traces.
Specifications: 3PS-02A60 Output voltage: 12V p-p (4.24V RMS), each phase output, P0, P1, P2 to common, G. Output voltage: 20.8V p-p (7.35V RMS), phase-to-phase outputs. Maximum current: 60mA RMS, each phase output, P1, P2, P3. Output frequency: 60Hz, ±0.2%. P0 = 0 deg. P2 = 120 deg. P3 = 240 deg. Harmonic distortion: less than 1%. Input power: +9 to +12VDC and -9 to -12VDC, 150mA maximum.
Here is a link to the data sheet:
