rlev
Junior Member level 3
I designing a 3-phase power meter using the CS5466 IC from cirrus logic
the final design should be power by one the phases (X,Y or Z)
the target systems are 3 phases systems with neutral included ( 120 vac Phase to neutral and 240 phase to phase).
The challenge is that whatever phase is present ( i.e. x,y or z) this one should power up the system ( the ac voltage will be break down to 5 vdc).
Any help will be highly appreciate.
rlev
rlev
