3 Phase Inverter with braking diodes
alexplace2001
Junior Member level 2
Mexico
3 phase inverter
Hello
I've seen that some 3 phase bridge topologies use three extra diodes in serires in the branch. This topology is shown in the image bellow.
For a BLDC motor drive, will this topology help to handle back EMF?
will this make a more robust brige?
what other considerations should be taken, to implement this?
Thanks in advance.
Alex
inverter braking
As one basic effect of the diodes, you're producing a risk to damage the high side transistors by overvoltage. The circuit also doesn't allow meaningful pwm operation. Unless you don't know, that the circuit is from a trustworthy source, you should better ignore it.
