3-phase inverter using PIC controller problem
adilmahsan
Pakistan
Hi
I'm designing a 3-phase inverter using PIC controller
I'm currently using Mosfet drivers but have no qualms with using IGBTs
Let's say i'm using IGBT's and dual supplies (positive and negative) as shown on the 5th page of the attached pdf file
Now, if the gate triggering circuit varies from 0 to 5 volts, then wouldnt the lower transistors be forward biassed at 0 and 5 volts???
Shouldnt they require a triggering signal that varies from -Vdc to -Vdc+5 V
Plz help
Thanx
3 phase inverter
-VDC is connect to logic ground in this circuit.
