cupoftea
Advanced Member level 6
The attached doesnt work to give a 100W -ish 3 phase delta supply.
The 5A fuse just blows very quick.
Is it mainly because of the leakage inductances?
Transformers used were Carroll & Meynell 3000VA.
Carroll & Meynell 3000VA Intermittent Isolation Transformer 230V/230V Blue - Screwfix
Order online at Screwfix.com. Rugged portable isolating transformer, designed to ensure an isolated supply when working on equipment connected to the mains supply. With a resettable thermal cut-out in the primary circuit to prevent overload. Glass-reinforced polymer case provides IP44 ingress...
www.screwfix.com
