3 phase cable ques.??
ahmed osama
Full Member level 6
Full Member level 6
Cairo, Egypt, Egypt
3 phase cable
Dear Sir
nice ques. , now always the 3 phase cable has 3 Live wire & 1 wire netural , now why always the guage the of the netural wire less than the main 3 live wires , although it carry the return currnet which it should have guage 3 times the live wire ??
thanks
bye
3 phase cables
Only in single phase applications is the current in the neutral equal to the current in the active phase.
In a balanced three phase supply the neutral would carry no current, the sum of currents over the three phases would equal zero.
Quite often even in a three phase balanced application the neutral will carry currents due to harmonics and other issues, and if disconnected will not be exactly at 0 volts.
Even in an unbalanced application the current going into a circuit will flow out on at least one other phase, therefore reducing the demand of the neutral which would only carry the difference.
As a side issue not all neutrals are lower gauge and not all three phase cables have a neutral.
what is a 3 phase cable
I have a simple general suggestion: Try to get an intuitive understanding of 3-phase AC systems operation.
Chapter 10 (Polyphase AC circuits) of the below internet text book is a good introduction.
cablage a troi phases
please sir (fvm) can helpe me another refrence about same subject
thank you
eng.ihssan
iraq -diyala university
3 p cable
Dear Ahmed,
The current in the nutral wire not three time the live wire, but if there is a large harmonics, the current in it is large. Canada put the nutral wiral larger than the live wire.
Good luck.
