3-Phase AC motor- blocking rotor
xirix
Full Member level 2
Full Member level 2
Romania
Did anyone know (as principle) how to block the ax of a 3-phase motor using the PWM signals?
It is needed by a emergency stop of rotor movement.
Thanks
Following the European rules about machines, for an emergency stop you cannot use any electronic system but only a brale ( breaks in case of missing power ).
It can be helped by electronics, but not electronics only.
Mandi
If you want to brake the AC motor you need to inject a DC current into stator.
This is as you fix a vecto in oune position and force the motor to follow this vector.
The induced current on the rotor perform resistive losses on it then take in account that before another braking action you need to cool enugth the rotor.
Bye.
