thebadtall
Full Member level 6
Hello, today I recieved a kit (tda2030) from ebay, woke up in the afternoon ^^ and soldered it.
My intention is to use it as final amp, preamped by an older project of tube preamp..
The results of the preamp was very good. The results of the preamp driven to the tda2030 amp, was better than expected ! (for a $7 amp and $5 preamp !!!)
The power supply is just Lipo 11.1v Battery. No noise, no hiss.. just pure 512k mp3 !
1. The kit
2. Populating the pcb
3. Almost done
4. The heatsinks used to be 1 big heatsink (for pc-psu), but was cut to 5 pieces
5. The left and right channel tube preamp circuits. As you notice there is no pcb.
Since I hadnt the time to make a pcb, i just put p2p the matterials in a protoboard!
Valves are 12au7
6. The lipo batteries! Even small they can run for hours. Used also in my R/C projects!!
1. The kit
3. Almost done
Valves are 12au7
