maijaz99
Junior Member level 3
rca 2n3055
I have made a 12V DC to 280V AC inverter using 2N3055 in push pull amplifier design and stepup transformer. But performance is not upto expectations. with three transistors attached to both sides of center taped 12V winding, the circuit calims to give 500W output but in actual it gives around 160W ouput, while the output of single 2N3055 is around 115W according to datasheet. The transistors are mounted on fairly large heatsink and get hot when load is increased from 160W. Can any body suggest what is the problem with this?
Thanks
Thanks
