2MHz oscilator circuit
A2k
Newbie level 3
Newbie level 3
oscilator circuit
Hi all.....
Has anyone got a design for a Oscilator circuit that generates a 2MHz square wave that they would not mind sharing.
Thanks a mil!!!!!!....
Cheers,
AK
2mhz crystal oscillator
Please check following site :
www.discovercircuit.com
2Mhz sqare can be easily generated using crystal oscillator and some gates.
One sample circuit is attached.
"Could not attach the sample circuit as it had some extension that was not permitted by the forum ,will try to convert it into jpeg soon and forward you "
Enjoy !!!
bye
crystal oscillator 2mhz
you can use the 555 timer from national semiconductor. in their datasheet, they have a oscillator wired up.
http://cache.national.com/ds/LM/LM555.pdf
if the output isn't nice, you can put it through a inverter to get a cleaner square wave.
oscilator 8,2mhz
The simplest way may be the invertor with 2MHz crystal connecting to in/out of the invertor.
