denver56
Member level 3
Hi people !
I am doing some input-referred noise tests on a Pcb. This Pcb is composed by 8 quad-op amp that filter and give gain to signals. Actually I made this test also on his twin boards and I didn't notice frequency noise. Instead in this Pcb there's a big noise at ouptut at 2Khz frequency even when the signal input is linked to the ground (see the attachment). I give supply to the board with a laboratory dc power supply (7 Volt) and obviously there are 2 electrolytic capacitors on the board. Anyone has some idea to how reduce this noise?
Thank you very much!
