Alper özel
Member level 1
- Joined
- Feb 28, 2015
- Messages
- 40
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Location
- Turkey / Scotland
- Activity points
- 487
We have a system that we can not change. Systems output is 2D video in DisplayPort format. Video is in 1080 p resolution and 120 Hz. We need to convert this 2D video to 3D in realtime. We will be able to get 3D depth map. Now, I have to prepare a preliminary design report. So I kinda have to figure out how to convert 2D video to 3D.
And I think FPGA is not an option since minimum data rate is 1.62 Gb/s and FPGA can not handle this much data processing. So it leaves embedded linux as an option. Thus first question: Am I right so far? If not, why?
Secondly, what are my options in specific? I think of Rasberry pi and blackbone. Second question: Are there any options? I already designed a backlight unit, active shutter glass and synchronizer and now I need to implement 3D conversion block on an external circuit. Have can I do that? Is it so hard? Should I go with rasberry pi? I don't know If the customers will be satisfied about it if I go with rasberry pi. And secondly, can rasperry pi handle displayport and 3D conversion?
So to summarize:
1) What are my options to process the video coming via DisplayPort and for 3D conversion?
2) Which option is the simplest one?
3) Could you explain the 3D conversion (with given depth map) method in general?
So to summarize:
