[SOLVED] [MOVED] Kaise SK-6111 help needed
amendar
Newbie level 6
Newbie level 6
Please,
I need circuit or schematic or service manual or ... for DMM Kaise SK-1611.
Thanks in advance.
i not found the schematic or service manual but which type of fault is in your dmm. does it shows any display ?
again that ic is having any manufacturer name or any other series no. like la, tda etc
No manufacturer mark on ic as its seen in the picture.
DMM does not turn on and no display, everything seems normal and ok, all components seem ok,
I could not check any volts in IC pins !
Working voltage is 2x1.5 volt battery and there is no regulator and no transistor,
I think its some special IC just for Kaise or any OEM manufacturer.
hi
3 Number of wires, the key service, has been discontinued. Please let the wires used to connect
I need circuit or schematic or service manual or ... for Kaise SK-1611.
thanks
