[SOLVED] how to perform an operation on value greater then 65535?
uday mehta
Full Member level 1
i me counting something from 0 to 99999. here if i use an integer and increment it then it will reached its limit i.e. 65535. which data type i can use in this code...
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
#include<reg51.h>
sbit ip = P3^0;
void delay(unsigned int p)
 int i,j;
 for(i=0;i<p;i++)
 for(j=0;j<1250;j++);
void main()
 int val[]={0xc0,0xf9,0xa4,0xb0,0x91,0x92,0x82,0xf8,0x80,0x90};
 int a,b,c,d,e,br,cr,dr,er,x;
 a=0;
 while(1)
 b=a/10000;
 br=a%10000;
 c=br/1000;
 cr=br%1000;
 d=cr/100;
 dr=cr%100;
 e=dr/10;
 er=dr%10;
 x=b;
 P1=0x80;
 P2=val[x];
 delay(10);
 x=c;
 P1=0x08;
 P2=val[x];
 delay(10);
 x=d;
 P1=0x04;
 P2=val[x];
 delay(10);
 x=e;
 P1=0x02;
 P2=val[x];
 delay(10);
 x=er;
 P1=0x01;
 P2=val[x];
 delay(10);
 while(ip==0);
 a=a+1;
 while(ip==1);
here i want that variable "a" reach to 99999... if i change the data type to double then "br=b%10000" gives an error.
Sizes of data types are implementation dependend. People use to consult a compiler's user manual to know about the details. Most compilers (e.g. Keil C51) implement the type long with 32 bit size
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
#include<reg51.h>
sbit ip = P3^0;
 int i,j;
 for(i=0;i<p;i++)
void main()
 a=0;
 while(1)
 b=a/10000;
 br=a%10000;
 c=br/1000;
 cr=br%1000;
 d=cr/100;
 dr=cr%100;
 e=dr/10;
 er=dr%10;
 x=b;
 P1=0x80;
 P2=val[x];
 delay(10);
 x=c;
 P1=0x08;
 P2=val[x];
 delay(10);
 x=d;
 P1=0x04;
 P2=val[x];
 delay(10);
 x=e;
 P1=0x02;
 P2=val[x];
 delay(10);
 x=er;
 P1=0x01;
 P2=val[x];
 delay(10);
 while(ip==0);
 a=a+1;
 while(ip==1);
for 16 bit compiler just assign as unsigned long int which 'll give you a range of 0 to 4294967296... For 32 bit compiler u can assign just as int to get the same range.
As you mention I guess you r using 16 bit compiler. So assign as unsigned long in...
i tried long int but first it reach to 65500 and then next time it reach to 35500(nearly). actually it is fast so i can't see exact value. but when i want to count from 00 to 999999 then it count 65500 then 35500 and add it. means whole program works fine but not display value from 65500 to 99999.
