TIMER FOR PIC 16f877a using mikroC
Danishmehmood
Newbie level 2
Newbie level 2
Hi all,
i am new in PIC for 16f877a, can anyone have any example on how to have a timer triggering in this PIC.
I want to make a system which will check value of Current, and then attach loads according to requirement.
There are three loads, when current increases from 10A, one of the load turns off.
I need a program which will check value of Current after every 5 or 10 Seconds using timer Interrupt. I cannot use Delay command because it will stop micro-controller from all other works. :sad:
Kindly tell me, some program so I can use it to run my project.
(In the CCT, Instead of placing MCU i wrote 'Logic to MCU' etc. EMR01.... is relay).
Hi all,
I have C code for timer but it is for Hi-Tech compiler so is it possible to use Hi-tech instead of Micro C.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
unsigned int time = 0;
//Timer1
//Prescaler 1:8; TMR1 Preload = 3035; Actual Interrupt Time : 500 ms
//Place/Copy this part in declaration section
void InitTimer1(){
  T1CON  = 0x39;
  TMR1IF_bit     = 0;
  TMR1H  = 0x0B;
  TMR1L  = 0xDB;
  TMR1IE_bit     = 1;
  INTCON     = 0xC0;
void Interrupt(){
  if (TMR1IF_bit){
    TMR1IF_bit = 0;
    TMR1H    = 0x0B;
    TMR1L    = 0xDB;
    //Enter your code here
    time++;
    if(time == 10){   //10 == 5 sec, 20 == 10 sec
        //do something
Thanks jayanth.devarayanadurga, i will learn it, n try to use it in mikroc. thanks alot.
