[SOLVED] Why J-link can not be recognized?
bianchi77
California
Friends,
why suddenly I can't recognized my J-Link, LED off and can not be recognized ?
any ideas ?
thanks
Re: J-link can not be recognized ? why ?
Is it a clone? Have you recently upgraded the drivers or software?
Many of the serial numbers used by clones have been blacklisted by Segger.
BigDog
yes it is a clone, last night it was running suddenly now it's off....
may be i can re install the software ?
thanks
no i didn't upgrade it, only re install keil, since I reinstall window, any solution ?
thanks
I got this message is it J-link hardware failure ?
i tried to reinstall the driver I got code 10 The device can not start, I guess it's hardware ( J-link) failure.....
Green LED is off as welll nothing happened...guys, any ideas, or it's time for me buying a new one ?
Re-update the firmware Jlink
Using an older version Jlink.dll driving under cover MDK
Known is a version available V4.40b
Can you tell me the details of it ? is it from keil for updating it ?
thanks
First, download and install the software SAM_BA_2.12.exe
Download from here:http://www.atmel.com/tools/atmelsam-bain-systemprogrammer.aspx
Second, open your Jlink shell
1 ERASE jumper shorting
2 Connect the USB cable to the PC
3 Wait approximately 120 seconds
4 Disconnect the USB cable
5 Disconnect the ERASE jumper
6 TST jumper shorting
7 Connect the USB cable to the PC
8 Wait for approximately 120 seconds
9 Disconnect the USB cable
10 Disconnect the TST jumper
11 Connect the USB cable to the PC
12 search install the driver pointing SAM-BA installation folder, if it is XP system, there will be a atm6124.Sys ATMEL AT91xxxxx Test Board hardware, if it is Win7, there will be a GPS Camera Detect (COMx) Hardware
13 Open the SAM-BA, where there would be a connection, if it is 0, you need to check the above steps
14 Keep the default settings, select a Jlink firmware moment to
15 of Jlink.dll first covered with 4.40b MDK drive, and then automatically update
16 completed
bin here
View attachment V8-4.24f.bin.7z
what should I do afer this ?
like this ?
my j link is working now ....thank you very much
I am not trying to revive old post, I just wanted to post some additional info for future googlers on my successful experience with this procedure.
If you follow steps 1 - 11 and plug in the USB cable and still get a USB device not recognized message from windows, repeat again but try the erase steps 1-3 a few times then on step 8 wait only 10s. Atmel docs say that the tst pin need only be held high for 10s then you can disconnect and pull the jumper and plug straight back in. I did this on windows 8 and after it took, I simply plugged it in and windows did the normal looking for driver thing.
When you start the sam-ba tool, be sure to run it as administrator or else you will get weird error messages and it will crash.
Thats my $0.02
Reactions: domble
    domble
