[SOLVED] Links to various Line Follower Robot designs
line follower robot based on mc
Hello
This might be nice too
comparator line follower
See this good line followin bots
**broken link removed** - Mike's Line Following Bots
circuit diagram of line follower
Thats really a nice book, I appreceiate it much.
Thanks again.
best linefollower bot circuit diagram
line follower robot and comparator
can anyone guide me ....i want to do a Line follower robot using 8051 controlller....want to program it for any paths...(line not only closed...but wen two line are encounterd it shud chose b/w them.....wen line ends it shud comeback and chose the other path as well)..
buy a line follower
can anyone suggest me a line following robot using 89c51.. and also abt ISP....
line follower 89c51
Ashok,
from what I see from all your posts here.. you have not yet made any bost so far ?
Concentrate first on making a bot using only comparator/opamp + HBridge...
Then move onto 8051 etc...
line follower bot circuit using 8051
actually ive done a line follower using 89c51rd2 mc...
tat was for my college mini project... but i dont hav a clear idea on how 2 burn the flash in 89c51....
robot line 89c51
Did you buy a kit from TRI India ?
Your college MUST be having a programmer for 8051.. use that.
no.. my colg doesnot have any programmer like tat.,...
circuit diagram line follower robot
i want to build line follower robot so, any can help me in giving circuit diagram and how to construct it
line follower robot
There are ample links given in this thread to the said subject. Select the one suits youu the most. Cheers
Added after 2 minutes:
The program is compliled and the resultant hex file is burnt in to the 89C51 chip with a programmer which comes with a programmer software. You may have a look at www.united77.com/89programmer.htm. Cheers
Line Follower Robot
i confuse tu programing my robot with c avr...can you help me??
Re: Line Follower Robot
this is LINE FOLLOWER ROBOT Using PIc microcontroller..
U can use PIC 16f877a for best features moreever.. in this ckt..
we r filtering it can be avoided when we use IR inputs to PORT A pins..
k try for that. one it wil wok out........
SRINU
best regards
Re: best linefollower bot circuit diagram
amolbook said:
http://students.iiit.ac.in/~saini_sandeep/pro2.html
i hav seen the circuit diagram. i have some confusions in connections.can u tell where the first terminal of fan is connected ??....
and what is "key=space " (J1 and J2) is that switch ??? or relay or anything else ?plz reply here or at psevekar@gmail.com
