vinodstanur
Advanced Member level 3
- Joined
- Oct 31, 2009
- Messages
- 751
- Helped
- 114
- Reputation
- 234
- Reaction score
- 114
- Trophy points
- 1,333
- Location
- Kerala (INDIA)
- Activity points
- 7,054
I am using lipo battery 3.7v and want to drive a circuit which works at 3.3v. My battery voltage can be in between 4.2v to 3v. So I selected TPS61201 buck boost regulator.
Is it a good choice ? My circuit current consumption in idle mode will be around 10 mA and some time it goes to 150 mA for few seconds and again comes down to 8 to 10mA.
I have a plan to reduce the idle mode current by using an accelerometer with interrupt which wake up the total system on shaking. At this time the current consumption will be negligible but I am worried about the buck boost regulator will take some power...
I can see a PS pin in the TPS61201 regulator and it says it can be used as power saver mode for the regulator and the efficiency chara shows that it have efficiency around 40% when the o/p current is as low as <1mA and close to 0mA.
So I have few questions,
Is it a good decision of selecting the TPS61201 buck boost regulator in this case? (3v to 4.2v -> 3.3v regulated)
What if I am taking zero o/p current or around 0.1mA O/P CURRENT? What will be the current consumed by the regulator at that time?
Also I am confused if I should always enable the PS (pull it down to enable power saver mode) even if the circuit takes its peak current around 150 mA. At this peak current will it cause any problem if I am enabling the power saver pin?
