dmta
Member level 2
- Joined
- Mar 25, 2013
- Messages
- 52
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Earth
- Activity points
- 1,650
Hi all !!!!!
I want to implement a PID motor position controller in PIC18F4431. I read the motor position using a quadrature encoder and use the built in QEI to get the motor position. The PID loop is calculated every 0.52S inside the TIMER1 overflow ISR. This is my code (all variables are global).
How do I now convert this to PWM to drive the motor ?
BTW I am using a 360 pulses per revolution quadrature encoder and operating in the X4 mode of the QEI module i.e. when the shaft rotates 1 round (360°) the motor max value of "POS" will be 360×4-1=1439
void interrupt(){
if(PIR1.TMR1IF==1){ // every 0.52 seconds the PID O/P is calculated
ERR_P1 = ERR_P2; // get previous position error
ERR_P2 = SET_P - POS; // calculate present position error
ERR_AC = ERR_AC + ERR_P2; // calculate accumilated error
PID_P = (float)Kp*ERR_P2 + (float)Ki*ERR_AC*0.52 + (float)Kd*(ERR_P2-ERR_P1)/(0.52);
PIR1.TMR1IF = 0;
