ma10adi
Newbie level 3
Hi
I have to design a Data Logger programusing mikroC PRO to run on the EasyPIC5 board (with PIC 16F877A microcontroller). I also have to use a 2-line LCD for display.
Here is what i have been given:
The program will take measurements from Analogue Port AN0 at regular intervals, and save the raw data to
EEPROM. The user should be able to select any of 6 memory banks to store the results of a logging session,
and should be able to set the time interval between readings at 1 second, 2 seconds, 5 seconds or 10
seconds. The number of readings taken in each logging session should be set to 5, but should be alterable from a #define in the first few lines of the program. Another #define should be used to specify the total number of memory banks (set to 6).
Having quite a bit of trouble with this.
Any help would be appreciated.
