[SOLVED] GSM module interfacing problem to AVR
Briez
Member level 5
Member level 5
Hello,
I want to interface GSM module with atmega32.
I have wrote a c code using avr studio 4 and compiler winavr using 16MHZ crystal.
But when i send sms sending AT command, GSM module doesnt send sms.
I have checked my gsm module in hyperterminal. It is an okay.
I am sending commands as follow,
AT\r
delay(1000); //millisecond
ATE0\r
AT+CMGF=1\r
AT+CMGS="xxxxxxxxxx"\r
delay(100); //millisecond
(Message)
Ctrl+Z
when i transmit "AT" to GSM it responds me with "PU".
What will be the problem?
Mention the functions used to send character and string to USART.
This code is for 8 MHz clock. delay is causing the problem. If you use 16 MHz clock then double the delays. The delays are not giving exact milliseconds.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
send_string("AT+CMGF=1");
send_data(0x0D);
send_data(0x0A);
_delay_ms(2000);
send_string("AT+CMGS=");
send_data(0x22);
send_string("974245XXXX");
_delay_ms(200);
send_data(0x22);
send_data(0x0D);
send_data(0x0A);
_delay_ms(500);
send_string("Hello from Jayanth");
send_data(0x0D);
_delay_ms(5000);
send_data(26);
send_data(0x0D);
_delay_ms(8000);
Reactions: Briez
    Briez
if i send AT+CMGR=1 some garbage data display on LCD.
My code is,
#define F_CPU 16000000UL
#include<avr/io.h>
#include<avr/interrupt.h>
#include <util/delay.h>
#include"LCD.h"
#define BAUD 9600
#define MYUBRR ((( F_CPU / ( BAUD * 16UL))) - 1)
#define rx_on	UCSRB|=(1<<RXCIE);
#define rx_off	UCSRB&=~(1<<RXCIE);
void uart_init(unsigned int ubrr);
void send_string(unsigned char *str);
void send_data(unsigned char back);
void reset_flush(void);
unsigned char ReceivedByte[200];
unsigned char count,i=0,j,k,data,AT_ack=1;
int main(void)
DDRB=0xFF;
DDRA=0xFF;
DDRC=0xFF;
DDRD=0xFE;
PORTD=0x00;
MCUCSR|=(1<<JTD);
MCUCSR|=(1<<JTD);
lcd_init();
uart_init(MYUBRR);
_delay_ms(500);
lcd_send_R1(0,"GSM_init");
sei();
_delay_ms(50);
rx_off;
_delay_ms(500);
while(1)
//								AT+CMGR=1									//
	send_string("AT+CMGR=1");				//send "AT" to GSM
	send_data(0x0D);
	send_data(0x0A);
	rx_on;							// checking response from GSM
	_delay_ms(10000);
	rx_off;
	for(k=0;k<16;k++)
	  	lcd_cmd(0x80+k);
		lcd_data1(ReceivedByte[k]);
		_delay_ms(500);
	for(k=16;k<32;k++)
	 	k=k-16;
		lcd_cmd(0xC0+k);
		_delay_ms(500);
	for(k=32;k<48;k++)
	 	k=k-32;
		lcd_cmd(0x80+k);
		_delay_ms(500);
	reset_flush();
	_delay_ms(5000);
return 0;
//							UART Initialization									//
UBRRH = (uint16_t)(ubrr>>8);
UBRRL = (uint16_t)ubrr;
UCSRB = (1<<RXEN)|(1<<TXEN)|(1<<RXCIE);
UCSRC = (1<<URSEL)|(3<<UCSZ0);
//									char send to UART							//
  while( !( UCSRA & (1<<UDRE)) ) ;
    UDR=back;
//									String send to UART							//
	while(*str)
         send_data(*str++);
//									Reset Buffer								//
  i=0;
  count=0;
  for(j=0;j<200;j++)
		ReceivedByte[j]='\0';
ISR ( USART_RXC_vect )
	count=UDR;
if(count!=0x0D && count!=0x0A && count!='>' && count!='"')					//Do not Print \r\n and ">"
	ReceivedByte[i]=count;
	i++;
if(i==200)
   i=0;
Where i am making mistake?
