16F877a MCU and HD44870 LCD
PA3040
Advanced Member level 3
Dear All
This is related to PIC 16F877a MCU and HD44870 LCD ( 4bit Mode)
My LCD and MCU connections are as follows.
RD4 to LCD data pin 4
RD5 to LCD data pin 5
RD6 to LCD data pin 6
RD7 to LCD data pin 7
LCD 0,1,2,3 pins are connected to GND
void lcddata(unsigned char value)
LCD_RS = 1;
LCD_DATA= (value&0xf0);
LCD_STROBE;
LCD_DATA = ((value<<4)&0xf0);
LCD_STROBE;
__delay_ms(10);
Above codes data write for 4bit mode and it is working
However my new hardware design was changed as follows
RD0 to LCD data pin 4
RD1 to LCD data pin 5
RD2 to LCD data pin 6
RD3 to LCD data pin 7
Could you please advice me how may I change my above lcddata program accordant to new hardware design
Thanks in advance
LCD_DATA MSB LSB interchanged
LCD_RS = 1;
LCD_DATA= ((val>>4)&0x0F);
LCD_STROBE;
LCD_DATA =(val&0x0F);
LCD_STROBE;
__delay_ms(10);
Reactions: PA3040
    PA3040
Dear Jestin thanks for the reply
I changed as follows but still problem remaining unchanged
Please advice
LCD_RS = 1;
LCD_DATA= ((value>>4)&0x0f);
LCD_STROBE;
LCD_DATA = (value&0x0f);
LCD_STROBE;
__delay_ms(10);
void lcdcmd(unsigned char value)
LCD_RS = 0;
LCD_STROBE;
LCD_STROBE;
__delay_ms(10);
Dear can you please check this program is correct
LCD_EN =0;
 __delay_us(10);
	LCD_DATA =0X30;
     	LCD_STROBE;
       	__delay_ms(2);
       LCD_RS=0;
       __delay_us(10);
	LCD_DATA =0X30;
     	LCD_STROBE;
	__delay_ms(2);
        LCD_RS=0;
       __delay_us(10);
	LCD_DATA =0X30;
       	LCD_STROBE;
	__delay_ms(2);
       LCD_RS=0;
       __delay_us(10);
	LCD_DATA =0X20;
     	LCD_STROBE;
	__delay_ms(2);
lcdcmd(0x28);
__delay_ms(15);
lcdcmd(0x01);
__delay_ms(10);
lcdcmd(0x06);
__delay_ms(10);
lcdcmd(0x80);
__delay_ms(10);
lcdcmd(0x0c);
__delay_ms(10);
Please advice
try this lcd init
LCD_EN =0;
 __delay_us(10);
	LCD_DATA =0X3;
     	LCD_STROBE;
       	__delay_ms(2);
       LCD_RS=0;
       __delay_us(10);
	LCD_DATA =0X3;
     	LCD_STROBE;
	__delay_ms(2);
        LCD_RS=0;
       __delay_us(10);
	LCD_DATA =0X3;
       	LCD_STROBE;
	__delay_ms(2);
       LCD_RS=0;
       __delay_us(10);
	LCD_DATA =0X2;
     	LCD_STROBE;
	__delay_ms(2);
Reactions: PA3040
    PA3040
Dear jestin thanks for the reply
Please accept my apologize for my fault
Actually Connection could be as follows
RD0 to LCD pin 7
RD1 to LCD pin 6
RD2 to LCD pin 5
RD3 to LCD pin 4
Can you Please modify the flowing codes for above connection
LCD_RS = 1;
LCD_STROBE;
LCD_STROBE;
__delay_ms(10);
LCD_RS = 0;
LCD_STROBE;
LCD_STROBE;
__delay_ms(10);
Please advice
Thanks in advance
void lcd_init()
       EN=0;
       LCD_RS = 0;
       __delay_us(10);
	LCD_DATA=0X0c;
     	ENBL;
       	__delay_ms(2);
       LCD_RS = 0;
       __delay_us(10);
	LCD_DATA=0X0c;
     	LCD_STROBE;
	__delay_ms(2);
         LCD_RS = 0;
       __delay_us(10);
	LCD_DATA=0X0c;
       	LCD_STROBE;
	__delay_ms(2);
        LCD_RS = 0;
       __delay_us(10);
	LCD_DATA=0X04;
     	LCD_STROBE;
	__delay_ms(2);
	lcdcmd(0X28);
	__delay_ms(5);
	lcdcmd(0X0);
	__delay_ms(5);
	lcdcmd(0X01);
	__delay_ms(5);
	lcdcmd(0X06);
	__delay_ms(5);
void lcddata(unsigned char val)
//8bit reversing
val = (val & 0x0F) << 4 | (val & 0xF0) >> 4;
val = (val & 0x33) << 2 | (val & 0xCC) >> 2;
val = (val & 0x55) << 1 | (val & 0xAA) >> 1;
LCD_RS = 1;
LCD_DATA=(val&0x0f);
LCD_STROBE;
LCD_DATA =((val>>4)&0x0f);
LCD_STROBE;
__delay_ms(10);
void lcdcmd(unsigned char val)
//8bit reversing
LCD_RS = 0;
LCD_STROBE;
LCD_STROBE;
__delay_ms(10);
Dear justing
Thanks for the reply
please see the codes and advice with wrong
#include <htc.h>
#define _XTAL_FREQ 4000000 // 4 MHz clock
__CONFIG(0X3F39);
#define LCD_EN RC6
#define	LCD_RS RC7
#define LCD_DATA	PORTD
#define	LCD_STROBE  LCD_EN = 1; __delay_ms(1); LCD_EN=0;
unsigned char time [6] = {"Time:"};
LCD_RS = 1;
LCD_DATA= (value&0x0f);
LCD_STROBE;
LCD_DATA = ((value>>4)&0x0f);
LCD_STROBE;
__delay_ms(10);
LCD_RS = 0;
LCD_STROBE;
LCD_STROBE;
__delay_ms(10);
void display (){
	lcdcmd(0x80);
		for (char i=0;i<5;i++){
			lcddata(time[i]);
void lcd_init(){
TRISD	= 0;
TRISB	= 0;
TRISC   = 0;
__delay_us(10);
lcdcmd(0x03);
__delay_us(10);
lcdcmd(0x03);
__delay_us(10);
lcdcmd(0x03);
__delay_us(10);
lcdcmd(0x2);
__delay_us(10);
LCD_STROBE;
__delay_ms(2);
lcdcmd(0x28);
__delay_ms(15);
lcdcmd(0x01);
__delay_ms(10);
lcdcmd(0x06);
__delay_ms(10);
lcdcmd(0x80);
__delay_ms(10);
lcdcmd(0x0c);
__delay_ms(10);
void main(){
        lcd_init();
			while(1){
				display();
Thanks in advance
Dear justing
Thanks for reply
I got the point
It was great lesson and i studied lot from you
Thanks again and again for help
PA3040
Dear justing
#include <htc.h>
__CONFIG(0X3F39);
#define LCD_EN RC6
#define	LCD_RS RC7
LCD_RS = 1;
LCD_STROBE;
LCD_STROBE;
__delay_ms(10);
LCD_RS = 0;
LCD_STROBE;
LCD_STROBE;
__delay_ms(10);
void display (){
	lcdcmd(0x80);
			lcddata(time[i]);
void lcd_init(){
TRISD	= 0;
TRISB	= 0;
TRISC   = 0;
__delay_us(10);
lcdcmd(0x03);
__delay_us(10);
lcdcmd(0x03);
__delay_us(10);
lcdcmd(0x03);
__delay_us(10);
lcdcmd(0x2);
__delay_us(10);
LCD_STROBE;
__delay_ms(2);
lcdcmd(0x28);
__delay_ms(15);
lcdcmd(0x01);
__delay_ms(10);
lcdcmd(0x06);
__delay_ms(10);
lcdcmd(0x80);
__delay_ms(10);
lcdcmd(0x0c);
__delay_ms(10);
void main(){
        lcd_init();
			while(1){
				display();
Thanks in advance
Dear justing
Thanks for reply
I got the point
PA3040
the above program is not working in proteus why?
This program is working'
  • PIC16F877 EEPROM 24LC64 Code.7z
Reactions: PA3040
    PA3040
sorry for the late reply sir i got the output with the help of saeed solutions could u guide me how to get more exposure in embedded programming and guide me to use this lcd program more efficient and easier thanks in advance.
//LCD DISPLAY INTERFACING IN PIC
#include<htc.h>
#include<pic16f877a.h>
#include<string.h>
#include<stdio.h>
#define _XTAL_FREQ 20e6
__CONFIG( FOSC_HS & WDTE_OFF & PWRTE_ON & CP_OFF & BOREN_ON & LVP_OFF & CPD_OFF & WRT_OFF & DEBUG_OFF);
#define load PORTB
#define rs RC0
#define rw RC1
#define en RC2
#define gas_sensor RC3
void delayms(unsigned int);
void lcd_cmnd(unsigned char);
void lcd_data( char);
void lcd_string(const char*);
void lcd_init(void);
void main(void)
TRISB=0;
TRISC0=0;
TRISC1=0;
TRISC2=0;
TRISC3=0X00;
load=0X00;
TRISC3=1;
lcd_init();
lcd_cmnd(0X80);
lcd_cmnd(0X01);
lcd_cmnd(0X80);
delayms(10);
lcd_string("RAJESH");
while(1)
if(gas_sensor==1)
lcd_init();
lcd_cmnd(0X01);
lcd_string("GAS LEAKAGE IN YOUR HOME");
delayms(10);
TRISC3=1;
void lcd_init()
lcd_cmnd(0X38); // configuring LCD as 2 line 5x7 matrix
lcd_cmnd(0X0C); // Display on, Cursor blinking
lcd_cmnd(0X01); // Clear Display Screen
lcd_cmnd(0X06); // Increment Cursor (Right side)
void lcd_cmnd(unsigned char command)
load=command;
rs=0;
rw=0;
en=1;
delayms(1);
en=0;
void lcd_string(const char *string)
while(*string)
lcd_data(*string++);
void lcd_data(char data)
load=data;
rs=1;
rw=0;
en=1;
delayms(1);
en=0;
void delayms(unsigned int delayms)
unsigned int i,j;
for(i=0;i<=delayms;i++)
for(j=0;j<=500;j++);
