usmanyousaf
Junior Member level 2
HI
i am using IRF540 MOSFETS with Rds(on)=44m ohm. using IR2110 to drive the MOSFETs at switching frequency 5kHz. the H bridge is used to drive a permanent magnet DC motor with current rating 3A MAX while the MOSFET can handle upto 33A (according to datasheet). there is a dead band delay of approx 3us(Hard wired). Freewheeling diodes are used in the circuit. Bootstrap cap is 2.2uF. Gate resistors are 10ohms. and motor operation voltage is 24V DC from an SMPS.
i made 4 PCB's, same design same component values. two of them work fine while other two have heating problem..the MOSFETS heat too much..what might be the reason.
is the bootstrap cap inappropriate...??
i,ve changed Driver ic's many times but it didnt help.
is there any way to check health of MOSFETS using multi meter..??
