Pictou
Member level 1
- Joined
- Mar 19, 2013
- Messages
- 34
- Helped
- 5
- Reputation
- 14
- Reaction score
- 5
- Trophy points
- 1,288
- Activity points
- 1,570
Hello,
I'm designing a crystal oscillator using the pierce model. I don't know how to validate my circuit.
So far I managed to measure the gain open loop (which is more than one at the wanted frequency, so oscillations should occur).
Then, when I want to close the loop and visualize oscillations it doesn't start at all.
I read on the internet that I had to set an initial condition on a capacitor to start the oscillations (I set 0V). It did start, but my oscillations are not maintained they are going lower and lower. This is the first problem.
The second one is : That my oscillations are not building up, they start at a huge amplitude immediately then go down.
I don't know what I did wrong. Theory says that I must have an inverter amplifier, I used a Common Source amplifier which amplifies and phase shift the signal so it should amplify the oscillations but it doesn't.
Do you have any clue about what is the problem?
Thank you.
Thank you.
