27MHz Radio Control System, my very first one...
hadihf
Full Member level 2
Full Member level 2
Planet Earth
sm6fie
Hi RC electronic buddies,
This is the very first one i made from PW 1979 issue. Feel free to ask any thing about it and I will be glad to help.
Regards
mc3357p mhz
Some more info,
Rx
L1=L2=L3=113CN2K509ADZ T/o/k/o 7mm Sheilded, P=8t, S=2t
L3 & L4 = 3rd IF Detector, Black, LLC4828 or similar
Tx
Shieded coil is as above
S18 is T/o/k/o moulded coil 0.39µH
Toroids are T37-12 M/i/c/r/o/m/e/t/a/l/s
turns are as shown on image
Regards
Hi Hadihf,
Thanks for this nice project! :)
Just one more question: MC3357P is obsolete now, and can be hardly found. Do You know a replacement part for it. Or anyone?
Thanks,
probert
Happy New Year for All!
These chips are similar and almost exact replacements with higher frequency range..
MC3361 ~60 MHz
MC3371 ~100MHz
MC3372 ~100MHz
Good Luck :D
hi,
is there any replecement for MC3357p it's not easy to find in indonesia
any same part from other manufactureer that avlaible in indonesia
hi,
You can find similar projects here
Where can I buy the joysticks?
ASIC
At that time I scraped these from an old 4ch f/u/t/a/b/a radio.
Regards
OK
Now, for the schematic. I have a couple of questions.
RX:
What's the wire thickness for L3, L4, L5?
Decoder:
What are typical resistor values for the joysticks and R5, R6, R7, R8, C6, C7, C8, C9?
ASIC
for winding the toroids use 28 swg insulated wire
if Pots are 5k then C6~9 = 2.2µF tantalum and R5~8 = 150
if Pots are 100k then C6~9 = 20nF and R5~8 = 100k
with tatalums + goes to IC 4017
hope this helps
Regards
for rx coils use Toko 7k coils. These have slots for wires...I think 38 swg will do. for 455 coils use pre wound as wire is very very thin
If anybody needs Rx coils, or any other hard to find parts, PM and may be I can help. :D
Regards
MicroStar 2000
Hi tic99,
No need to upload what is available freely on web, just post the link.
www.mstar2k.com
BTW already made Microstar2000 8) see attachments..
A super fantastic work by GAA.
Regards
Talking about receivers...
RX18 from above site 8) , see attachment
Regards
just a point of interest old cordless phones have most of the key parts for the receiver have found resonators and 3357 as well as mc 3361 and 3362 lots beeing frown away now
