Error while compilng systemc part of UVMC-2.2
er.akhilkumar
Full Member level 2
Full Member level 2
Noida
Hello All,
I have downloaded uvmc-2.2 from Verification Academy website. Now I am trying to compile its src/connect/sc part using sccom on free version. But, unfortunately it is showing errors in uvmc_connect.h file. I have used the command specified in uvmc-2.2/lib/Makefile in Windows 7. Please help me how can I remove these errors.
Thanx
Here are the errors reported by sccom:
uvmc-2.2\src\connect\sc\/uvmc_connect.h:510: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_put_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_blocking_put_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:510: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:510: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:510: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:510: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: At global scope:
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_put_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_blocking_put_if<RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:511: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_put_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_nonblocking_put_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:511: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:511: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:511: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:511: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_put_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_nonblocking_put_if<RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:512: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_put_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_put_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:512: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:512: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:512: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:512: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_put_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_put_if<RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:513: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_get_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_blocking_get_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:513: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:513: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:513: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:513: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_get_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_blocking_get_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:514: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_get_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_nonblocking_get_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:514: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:514: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:514: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:514: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_get_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_nonblocking_get_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:515: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_get_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_get_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:515: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:515: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:515: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:515: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_get_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_get_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:516: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_peek_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_blocking_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:516: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:516: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:516: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:516: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_peek_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_blocking_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:517: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_peek_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_nonblocking_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:517: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:517: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:517: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:517: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_peek_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_nonblocking_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:518: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_peek_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:518: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:518: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:518: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:518: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_peek_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:519: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_get_peek_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_blocking_get_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:519: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:519: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:519: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:519: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_get_peek_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_blocking_get_peek_if<RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:520: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_get_peek_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_nonblocking_get_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:520: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:520: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:520: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:520: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_get_peek_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_nonblocking_get_peek_if<RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:521: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_get_peek_port<T, uvmc_converter<T> >& uvmc::uvmc_connect(tlm::tlm_get_peek_if<T>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:521: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:521: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:521: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:521: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_get_peek_port<T, CVRT>& uvmc::uvmc_connect(tlm::tlm_get_peek_if<RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:524: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_transport_port<REQ, RSP, uvmc_converter<T>, uvmc_converter<T2> >& uvmc::uvmc_connect(tlm::tlm_transport_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:524: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:524: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:524: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:524: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_transport_port<REQ, RSP, CVRT_REQ, CVRT_RSP>& uvmc::uvmc_connect(tlm::tlm_transport_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:525: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_master_port<REQ, RSP, uvmc_converter<T>, uvmc_converter<T2> >& uvmc::uvmc_connect(tlm::tlm_blocking_master_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:525: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:525: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:525: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:525: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_master_port<REQ, RSP, CVRT_REQ, CVRT_RSP>& uvmc::uvmc_connect(tlm::tlm_blocking_master_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:526: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_master_port<REQ, RSP, uvmc_converter<T>, uvmc_converter<T2> >& uvmc::uvmc_connect(tlm::tlm_nonblocking_master_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:526: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:526: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:526: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:526: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_master_port<REQ, RSP, CVRT_REQ, CVRT_RSP>& uvmc::uvmc_connect(tlm::tlm_nonblocking_master_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:527: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_master_port<REQ, RSP, uvmc_converter<T>, uvmc_converter<T2> >& uvmc::uvmc_connect(tlm::tlm_master_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:527: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:527: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:527: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:527: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_master_port<REQ, RSP, CVRT_REQ, CVRT_RSP>& uvmc::uvmc_connect(tlm::tlm_master_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:528: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_slave_port<REQ, RSP, uvmc_converter<T>, uvmc_converter<T2> >& uvmc::uvmc_connect(tlm::tlm_blocking_slave_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:528: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:528: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:528: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:528: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_blocking_slave_port<REQ, RSP, CVRT_REQ, CVRT_RSP>& uvmc::uvmc_connect(tlm::tlm_blocking_slave_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:529: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_slave_port<REQ, RSP, uvmc_converter<T>, uvmc_converter<T2> >& uvmc::uvmc_connect(tlm::tlm_nonblocking_slave_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:529: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:529: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:529: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:529: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_nonblocking_slave_port<REQ, RSP, CVRT_REQ, CVRT_RSP>& uvmc::uvmc_connect(tlm::tlm_nonblocking_slave_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:530: error: expected ',' or '...' before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_slave_port<REQ, RSP, uvmc_converter<T>, uvmc_converter<T2> >& uvmc::uvmc_connect(tlm::tlm_slave_if<REQ, RSP>&)':
uvmc-2.2\src\connect\sc\/uvmc_connect.h:530: error: 'lookup' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:530: error: 'packer' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:530: error: 'stack_size' was not declared in this scope
uvmc-2.2\src\connect\sc\/uvmc_connect.h:530: error: expected primary-expression before 'struct'
uvmc-2.2\src\connect\sc\/uvmc_connect.h: In function 'uvmc::uvmc_slave_port<REQ, RSP, CVRT_REQ, CVRT_RSP>& uvmc::uvmc_connect(tlm::tlm_slave_if<REQ, RSP>&)':
Have you read the User Guide about the supported g++ compilers supported by your simulator? You cannot use the free sccom to compile SystemC code that will be linked into a SystemVerilog simulation.
The supported version for gcc for my simulator is Minimalist GNU for Windows (MinGW) gcc 4.2.1. I have it installed on my hard-disk.
I have tried compiling the sv part of the uvmc-2.2. It compiled successfully.
Then I tried compiling the sc part using sccom and it failed with the above mentioned errors. Command used was,
sccom -32 -cpppath $gcc_4.2.1_install_dir\bin\g++.exe -work uvmc-2.2 -Wall -g -I $modelsim_install_dir\include\ $modelsim_install_dir\verilog_src\uvmc-2.2\src\connect\sc\ $modelsim_install_dir\verilog_src\uvmc-2.2\src\connect\sc\uvmc.cpp
Then i tried to compile using the command
$gcc_4.2.1_install_dir\bin\g++.exe -I $modelsim_install_dir\include\systemc -I $modelsim_install_dir\include\ $modelsim_install_dir\verilog_src\uvmc-2.2\src\connect\sc\uvmc.cpp
same errors were found.
Replacing the recommended gcc with the latest verision supplied by MinGW - gcc 4.6.2, I dont get any errors but the output file (obj file) is still not created, even after adding the option -o new.obj
What can be the possible way to use the uvmc library in my uvm based TB.
