need matlab code for features exctraction using MFCC
kareem dsp
Junior Member level 1
hi all
i need matlab code for features exctraction using MFCC to use these featurs in dialect recognition
Hi i have a code and pdf for feature extraction using MFCC for speaker recognition. I will attach that please check it and use it if helpful.
AI=analoginput('winsound',1);
addchannel(AI,1);
set(AI,'samplerate',16000);
set(AI,'samplespertrigger',2*16000);
set(AI,'triggertype','immediate');
start(AI);
data=getdata(AI);
fs=16000;
%file = sprintf('%s%d.wav','database_new kar',i);
%%wavwrite(data,16000,file);
%% Computing MFCC Co-efficients..
    %% (1) Frame Blocking..
    N = 256;   % N point FFT
    M = 100;   % Overlapping
    NN = floor(N/2+1); %N/2
    nbFrames = ceil((length(data)-N)/M);
    Frames = zeros(nbFrames+1,N);
    for i = 0:nbFrames-1
        temp = data(i*M+1:i*M+N);
        Frames(i+1,1:N) = temp;
    end
    % Last Frame..
    temp = zeros(1,N);
    lastLength = length(data)- nbFrames*M;
    temp(1:lastLength) = data(nbFrames*M+1:(nbFrames*M +1 + lastLength-1));
    Frames(nbFrames+1, 1:N) = temp;
    %% (2) Windowing..
    frameSize = size(Frames);
    nbFrames = frameSize(1);
    nbSamples = frameSize(2);
    % Hamming window..
    w = hamming(nbSamples);
    Windows = zeros(nbFrames,nbSamples);
    for i = 1:nbFrames
        temp = Frames(i,1:nbSamples);
        Windows(i, 1:nbSamples) = w'.*temp;
    end
    %% (3) Fourier Transform..
    ffts = fft(Windows');
    %% (4) Mel-frequency Wrapping..
    % (a) Calculate Power spectrum..
    PowSpecs = abs(ffts).^2;
    PowSpecs = PowSpecs(1:NN-1,:);
    % (b) Mel filter generation
    nof_c = 20; % Number of channels..
    df = fs/N;
    Nmax = N/2;
    fmax = fs/2;
    % Convert to mel scale..
    melmax = 2595*log10(1+fmax/700);
    melinc = melmax/(nof_c+1);
    melcenters = (1:nof_c).*melinc;
    % Convert to frequency scale..
    fcenters = 700*((10.^(melcenters./2595))-1);
    centerf = round(fcenters./df);
    startf = [1,centerf(1:nof_c-1)];
    stopf = [centerf(2:nof_c),Nmax];
    W = zeros(nof_c,Nmax);
    % Making filter..
    for i = 1:nof_c
        increment = 1.0/(centerf(i)-startf(i));
        for j = startf(i):centerf(i)
            W(i,j) = (j-startf(i))*increment;
        end
        decrement = 1.0/(stopf(i)-centerf(i));
        for j = centerf(i):stopf(i)
            W(i,j) = (j-centerf(i))*decrement;
        end
    end
    % Normalising..
    for i = 1:nof_c
        W(i,:) = W(i,:)/sum(W(i,:));
    end
    % (c) Apply mel filters to Power spectrum coeffs..
    melPowSpecs = W*PowSpecs;
    % (d) MFCC calculations..
    melCeps = dct(log(melPowSpecs));
    melCeps(1,:) = [];
    load CodeBook
	dist_min = inf;
	spkr = 0;
	for ind = 1:length(codebook)
		single_cb =  codebook{ind};
		[M1, N1] = size(melCeps);
		[M2, N2] = size(single_cb);
		dist_temp = zeros(N1,N2);
		if N1<N2
            repli = zeros(1,N2);
            for n1 = 1:N1
                dist_temp(n1,:) = sum((melCeps(:,n1+repli) - single_cb).^2,1);
            end
        else
            repli = zeros(1,N1);
            for n2 = 1:N2
                dist_temp(:,n2) = sum((melCeps - single_cb(:,n2+repli)).^2,1);
            end
        end
        dist_temp = sqrt(dist_temp);
		dist_val(ind) = sum(min(dist_temp,[],2))/size(dist_temp,1);
		if dist_val(ind) < dist_min
            dist_min = dist_val(ind);
			spkr = ind;
		end
	end
	msg = sprintf('The Speaker is found);
    	disp(msg);
pdf:
  • Speaker Recognition - Using MFCC.pdf
addchannel(AI,1);
start(AI);
data=getdata(AI);
fs=16000;
    end
    % Last Frame..
    temp = zeros(1,N);
    %% (2) Windowing..
    % Hamming window..
    for i = 1:nbFrames
    end
    df = fs/N;
    Nmax = N/2;
    fmax = fs/2;
    % Making filter..
    for i = 1:nof_c
        end
        end
    end
    % Normalising..
    for i = 1:nof_c
    end
    melCeps(1,:) = [];
    load CodeBook
	dist_min = inf;
	spkr = 0;
		if N1<N2
            for n1 = 1:N1
            end
        else
            for n2 = 1:N2
            end
        end
			spkr = ind;
		end
	end
    	disp(msg);
pdf:
thank you Sir for you interest but i can't see the PDF file
cant you see the link there....i am attaching it here plz check...in the code i have commented a portion showing MFCC Coefficients i think that will be helpful for you... i know it is a complex code just take the portion you wanted
pdfView attachment Speaker Recognition - Using MFCC.pdf
addchannel(AI,1);
start(AI);
data=getdata(AI);
fs=16000;
    end
    % Last Frame..
    temp = zeros(1,N);
    %% (2) Windowing..
    % Hamming window..
    for i = 1:nbFrames
    end
    df = fs/N;
    Nmax = N/2;
    fmax = fs/2;
    % Making filter..
    for i = 1:nof_c
        end
        end
    end
    % Normalising..
    for i = 1:nof_c
    end
    melCeps(1,:) = [];
    load CodeBook
	dist_min = inf;
	spkr = 0;
		if N1<N2
            for n1 = 1:N1
            end
        else
            for n2 = 1:N2
            end
        end
			spkr = ind;
		end
	end
    	disp(msg);
pdf:
this part is for what sir? please help me...:smile:
addchannel(AI,1);
start(AI);
addchannel(AI,1);
start(AI);
This section is to connect a recording device for example a mic into matlab environment. Analog input function selects the input device. add channel will create the device object. then triggering properties are varied using the set keyword.
addchannel(AI,1);
start(AI);
data=getdata(AI);
fs=16000;
    end
    % Last Frame..
    temp = zeros(1,N);
    %% (2) Windowing..
    % Hamming window..
    for i = 1:nbFrames
    end
    df = fs/N;
    Nmax = N/2;
    fmax = fs/2;
    % Making filter..
    for i = 1:nof_c
        end
        end
    end
    % Normalising..
    for i = 1:nof_c
    end
    melCeps(1,:) = [];
    load CodeBook
	dist_min = inf;
	spkr = 0;
		if N1<N2
            for n1 = 1:N1
            end
        else
            for n2 = 1:N2
            end
        end
			spkr = ind;
		end
	end
    	disp(msg);
pdf:
Hi sir,
i tried run your code but it seems there appear some "cut-off" triangular filters(normalized,image - MFCCfilters(Sir's Code) ) instead of the triangular filter ouput(only image) that i took from one internet source (normalized,bottom image of image - TriFilterBank(From other source)). Can sir explain to me about this ? Thanks. =)
Hi sir,
Actually the code written above is for voice recognition and not for image recognition that may be the problem with you
No sir, you misunderstood what i meant. The images that i mentioned and attached are the MFCC filter graph plotted. Not related to image recognition at all. I tried your code to plot out the triangular filters but it seems some "cut-off" triangular filters there...
sir, if this is the code for feature extraction using mfcc, please could you give me the code for feature extraction using fft (i have to input the wav signal using wavread)
please could you help me.
addchannel(AI,1);
start(AI);
data=getdata(AI);
fs=16000;
    end
    % Last Frame..
    temp = zeros(1,N);
    %% (2) Windowing..
    % Hamming window..
    for i = 1:nbFrames
    end
    df = fs/N;
    Nmax = N/2;
    fmax = fs/2;
    % Making filter..
    for i = 1:nof_c
        end
        end
    end
    % Normalising..
    for i = 1:nof_c
    end
    melCeps(1,:) = [];
    load CodeBook
	dist_min = inf;
	spkr = 0;
		if N1<N2
            for n1 = 1:N1
            end
        else
            for n2 = 1:N2
            end
        end
			spkr = ind;
		end
	end
    	disp(msg);
pdf:
Thank you sir for this code. I am also working of automatic speaker recognition with MFCC. Will you please share the complete code us for speaker recognition.??
APHNASEEM:
sir what is cookbook, is it file or function can you give me plz,..
    V
hello sir i tried this code but can't understand ...... this codebook.......... and also this is not working
please tell me
i am sorry sir the above code is not mine their is some mistake i uploaded another one which is in fact not mine i mean i didn't write i download it from internet site
is there any different between code of feature extraction using MFCC for speaker recognition and speech recognition?
addchannel(AI,1);
start(AI);
data=getdata(AI);
fs=16000;
    end
    % Last Frame..
    temp = zeros(1,N);
    %% (2) Windowing..
    % Hamming window..
    for i = 1:nbFrames
    end
    df = fs/N;
    Nmax = N/2;
    fmax = fs/2;
    % Making filter..
    for i = 1:nof_c
        end
        end
    end
    % Normalising..
    for i = 1:nof_c
    end
    melCeps(1,:) = [];
    load CodeBook
	dist_min = inf;
	spkr = 0;
		if N1<N2
            for n1 = 1:N1
            end
        else
            for n2 = 1:N2
            end
        end
			spkr = ind;
		end
	end
    	disp(msg);
pdf:
hi can u help me how you created codebook in speech recognition
hello
can u help me to run this code,and making my coodbook?
hello sir!
i tried to execute your code but there is an error in loading the codebook!
can u please help me solvig the problem :(
