Servo control problem
nagsaver
Junior Member level 1
I am using a ATMega32a to control VTS-08B servo motor.I am using the microcontroller with a 16MHz external crystal.
Low fuse byte=0XFF High Fuse byte=0XC9.Here is the code..
#include <avr/io.h>
#include <util/delay.h>
void main()
   //Configure TIMER1
   TCCR1A|=(1<<COM1A1)|(1<<COM1B1)|(1<<WGM11);        //NON Inverted PWM
   TCCR1B|=(1<<WGM13)|(1<<WGM12)|(1<<CS11)|(1<<CS10); //PRESCALER=64 MODE 14(FAST PWM)
   ICR1=4999;  //fPWM=50Hz (Period = 20ms Standard).
   DDRD|=(1<<PD4)|(1<<PD5);   //PWM Pins as Out
   while(1)
      OCR1A=125;   //0 degree-0.5ms pulse
      _delay_ms(1000);
     OCR1A=316;  //90 degree-1.264 ms pulse
     _delay_ms(1000);
     OCR1A=650;  //180 degree-2.6 ms pulse
    _delay_ms(1000);
What happens is when the servo is powered it rotates to 0 degree initially from wherever it starts....after that it doesnt move at all.but I do get a weak sound of something vbrating inside the servo...What may be the problem?Or is it something wrong with the pulse duration?
I have reposted the thread in the appropriate forum.The moderator may remove this thread if necessary.
Your code wont work with servos. If you have an oscilloscope attach one channel to OC1A pin and see the produced PWM and compare it with the graphs from the picture attached. I wont give you code for this instead I'll give a link to a video that will help you understand the operation of servo motors and also help you write your own code that will meet your project's specifications.
https://www.youtube.com/watch?v=dmjvHvw3Rc8
