help how i use gate drive ir2110 or ir2112
Rehab.Hsn
Newbie level 1
Newbie level 1
hello. i am trying to dirve four mosfet with a microcontroller so i can implement PWM on a dc motor. i am using atmega16 and the dc motor is 12v. i have IR2112 or ir2110 to drive them. i have no idea on how use the IR2112 driver. can some1 please enlighten me with a schematic? so i know which pin is used for what purpose. i dont have time to do all searching about it .
Thanks in advance.
You can use this circuit:
You should go through this: www.irf.com/technical-info/appnotes/an-978.pdf
You could go through these threads:
https://www.edaboard.com/threads/219997/
https://www.edaboard.com/threads/238682/
https://forum.allaboutcircuits.com/showthread.php?t=27306
Hope this helps.
Tahmid.
