CAN Implementation Using PIC16F877A and MCP2515
Jestin_cubetech
Advanced Member level 1
CAN Implementation Using PIC16F877A , MCP2515 CAN controller and MCP2551 CAN Transceiver.
3 Nodes
CAN NODE A,CAN NODE B and CAN NODE C
this example shows..
CAN NODE A request ADC data from CAN NODE B
CAN NODE B send ADC value to CAN NODE A.
CAN NODE C send ADC value to CAN NODE A.
CAN NODE A Send LED SET/CLEAR commands to CAN NODE B
CAN NODE A Send LED SET/CLEAR commands to CAN NODE C
controller : PIC16F877A
C compiler : PIC CCS
Schematic and PCB Designing Tool : Proteus
https://users.ece.utexas.edu/~valvano/Datasheets/MCP2551.pdf
circuit diagram
Files:
unfortunately MCP2515 simulation is not available in Proteus...
  • CAN_hex_files_and_simulations.zip
this project developed from PIC-CCS CAN example program.
  • PIC-CCS CAN Example.rar
install PIC-CCS
library location
C:\Program Files\PICC\Drivers\can-mcp251x.c
C:\Program Files\PICC\Drivers\can-mcp251x.h
hello, I have two PIC18F458 communicate through can and wanted to pass this on to pic18f258 since they are smaller and spare space on pcb but does not work when I try to do it.
is there any difference in the pic can libraries.
Thanks!!
Hello Jestin,
I went through your blog. From the .C files used in your project, we find that the code developed by you is I2C code and the SPI is not used. From the MCP2515 datasheet, we find that the IC supports only SPI communication. Kindly enlighten on your project.
We are using a PIC16F876 and MCP2515 CAN IC. We are not able to establish the connection via SPI.
PICC MCP header file mcp251x.c
it use SPI Protocol not i2c.
Can i have the can-mcp251x.c file
I could not locate any spi initiation etc.,
The can-mcp251x.c and can-mcp2510.c are the same files.
The below function from can-mcp251x.c. The code is of I2C and not the SPI.
void mcp2510_command(int command) {
   int i;
   output_low(EXT_CAN_CS);
   for (i=0;i<8;i++) {
      output_bit(EXT_CAN_SI, shift_left(&command,1,0));
      output_high(EXT_CAN_SCK);
      output_low(EXT_CAN_SCK);
   output_high(EXT_CAN_CS);
Hello Jestin,
Could you kindly let us know what state do we need keep the TXnRTS pins to enable transmission. We are using two nodes now. When we try to send data from one node to another, the data gets loaded onto the TXBUF but does not go on the CAN bus. The TXBUF remains full thereafter. With the second node, there is no interrupts / RXBUF flags are not set.
Is it possible to analyse my code and suggest me the modifications? I am using a PIC16F876 controller with MCP2515. My project is compiled with CCS.
