Need schematics for rs232 programer for pickit programer :)
elementHTTP
Hi there
I need schematic for rs232 programer for pic18F2550 and/or pic18F4550 pls :D
these are pickits whit usb
variant 1. uses pic18F2550
and/or
variant 2. uses pic18F4550
to use these first i need to build rs232 programer for pic18F2550 and/or pic18F4550 to program them
thanks
Thanks for quick answer !
few noob questions
- for these two they use 16f series can i use it for pic18F2550 and/or pic18F4550 ?
JDM With External Power - Some Help Needed
pic serail programmer
- is it good idea to use usb to rs232 converter ( lack of serial port ) ?
JDM programmers are dependent on the software used as to which PICs they can program. The 18F2550/4550 are supported in the software I have seen. Read the Advanced JDM Programmer link for some software.
Usually, JDM-style programmers need a real RS232 port because they make use of the real RS232 signal levels to make a voltage multiplying power supply. Often (most/all?) USB-Serial converters do not have the required output levels, so probably will not work.
However, Fragrance's Advanced JDM circuit is externally powered and does not depend on the serial port for power, so this one might work on a USB converter. Why not ask in that thread for advice on that matter?
Another alternative is this circuit, which generates its power supply from a USB connection (only power, not USB data, and you would need another USB socket for the converter) so again, this might work with a USB converter for the serial.
Please note that I have not tried the above circuit, or Fragrance's circuit, since I made my own JDM programmer a long time ago and programmed another PIC to make a better programmer.
Hmmm this is getting little complicated :)
is there a way to upload data ( or program it ) direly from usb to PIC ?
instead going to such conversion from rs232 to usb
something like this ( it uses Ft232RQ)
https://www.picaxe.com/docs/axe027.pdf
( schematics at last page 16)
As FoxyRick rightly pointed out JDM programmers wont work propperly when you use usb to rs232 converter try to burn your HEX file from a good old PC having rs232 port
regards ani
Yes, that looks like a power supply. It's hard to see exactly on the breadboard, but you can see wires hopping from the suspected PSU to the power lines on the PIC.
