Can anyone help me with the verilog code of leading zero anticipator.
Its working seems a little tricky!
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 module leading_zero ( input [BIT_W-1:0] d_in, output reg [BIT_W-1:0] d_out, output reg [NR_W-1:0] nr_of_zero, output reg [NR_W-1:0] one_position ); localparam BIT_W = 16, NR_W = log2(BIT_W); reg [BIT_W-1:0] clr; genvar i; generate for ( i=0; i<BIT_W-1; i=i+1) begin: CLR always @* clr[i] <= |d_in[BIT_W-1:i+1]; end endgenerate always @* clr[BIT_W-1] <= !d_in[BIT_W-1]; genvar x; generate for (x=0; x<BIT_W; x=x+1) begin: lead_1 ff_set_clr ff ( .set(d_in[x]), .clr(clr[x]), .q(d_out[x]) ); end endgenerate integer y; always @* for ( y=0; y<BIT_W; y=y+1 ) if ( d_out == 0 ) nr_of_zero <= 0; else if ( d_out[y] ) nr_of_zero <= BIT_W-1 - y; always @* for ( y=0; y<BIT_W; y=y+1 ) if ( d_out == 0 ) one_position <= 0; else if ( d_out[y] ) one_position <= y + 1'b1; ///////////////////////////////////////////////// function integer log2 ( input [31:0] value ); // begin value = value-1; // for (log2 = 0; value > 0; log2 = log2+1) // value = value >> 1; // end // endfunction // ///////////////////////////////////////////////// endmodule module ff_set_clr ( input set, clr, output reg q ); always @(posedge set or posedge clr) if ( clr ) q <= 1'b0; else if ( set ) q <= 1'b1; else q <= q; endmodule
Thanks for the quick reply! found it useful
