vhdl unconstrained array port
shaiko
Advanced Member level 5
I want to create a new VHDL type inside a package called "2d_array" .
This type will be used as an array entity intput port (or output port).
I want the port's diementions to be unconstrained in order be able to define the exact size during compilation with 2 entity generic :
"2d_array_port_depth" and "2d_array_port_width".
Is it possible with VHDL?
If yes, please show me an example.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
PACKAGE 2d_array_pkg IS
TYPE 2d_array IS ARRAY(15 DOWNTO 0) OF STD_LOGIC_VECTOR(31 DOWNTO 0);
END 2d_array_pkg;
with VHDL 1993, you cannot leave all dimensions unconstrained, only the outer most one. eg:
type 2d_array_t is array(integer rage <>) of std_logic_vector(31 downto 0);
but with VHDL 2008, you can do this:
type 2d_array_t is array(integer rage <>) of std_logic_vector;
signal my_input : 2d_array_t(15 downto 0, 31 downto );
but you will need a compiler with 2008 support. otherwise you'll have to put the generics as constants in a package to define the type.
Thanks for replying dftrtl,
However - this doesn't help.
You define an array of known and constant diementions!
I want to define a type that can be used as an array input port with the exact diementions set only during compile time using entity generics...
TrickyDicky,
So with VHDL 93 we cannot create an array input port with completely generic diementions?
you can create a true 2d array with vhdl 93
type my_2d_array_t is array(integer range <>, integer range <>) of integer;
and declare:
signal a : my_2d_array_t(0 to N, 0 to M);
but I wouldnt recommend using std_logic, as it is a pain to map to std_logic_vectors, as you have to assign it bit by bit if you want a whole array.
Reactions: shaiko
    shaiko
I don't understand what you mean...
this is a generic array definitions:
type GENERIC_ARRAY is array ( 0 to GENERIC_DEPTH - 1 ) of unsigned ( GENRIC_WIDTH - 1 downto 0 ) ;
signal SOME_GENERIC_ARRAY : GENERIC_ARRAY ;
But that's inside an entity in the signal definitions area!
I want to be able to define an entity port in the same manor...
unless its VHDL 2008, you cant. You have to make the generics constants inside a package and declare the type in the package too.
Reactions: shaiko
    shaiko
In VHDL 2008, the actual width of an unconstrained component port can be set by connecting a constrained signal in the instantiation, you won't even need generics for it. I didn't check it, but it's discussed as an example in a text book VHDL 2008 - Just the New Stuff.
Reactions: shaiko
    shaiko
Please show me an example (using VHDL 2008) of what I want to do (explained in post #6)...
type GENERIC_ARRAY is array (natural range <> ) of unsigned;
signal SOME_GENERIC_ARRAY : GENERIC_ARRAY(0 to GENERIC_DEPTH - 1 , GENRIC_WIDTH - 1 downto 0) ;
Reactions: shaiko
    shaiko
