[SOLVED] Problem in setting the Baud Rate in AVR...
ismbn
Full Member level 3
Full Member level 3
Mumbai. india
Hello...
I am using the AT MEGA 32 and AVR studio 4.
In that i have given the F_CPU = 16000000 i.e 16MHz.
The Problem is I giving the UBRR = 51 (or any other value given in the data sheet) as given in the data sheet to set the Baud rate 19200.
But in the Hardware as well as in Simulation it is not working on 19200. but it is working on Baud Rate 2400(and if i am giving 103 for 9600 it is working on 1200). What can be the problem please guide me.
I am using Crystal of 16MHz, Is using the crystal of 16MHz is right or i have to use low value of crystal ?
here is the code:
#include <avr/io.h>
#include <avr/interrupt.h>
int i=0,j=0;
int main (void)
int a;
DDRA=0xFF;
DDRB=0xFF;
    a=51;           // to set the boud rate 19200
    UBRRL = a;
    a=a>>8;
    UBRRH = a;
    UCSRB |= (1 << RXEN) | (1 << TXEN);   // Turn on the transmission and reception circuitry
    UCSRC |= (1<<U2X)| (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1); // Use 8-bit character sizes
//   UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
//   BAUD_PRESCALE=(BAUD_PRESCALE>>8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
//   UBRRH = (BAUD_PRESCALE>>8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
   UCSRB |= (1 << RXCIE);// Enable the USART Recieve Complete interrupt (USART_RXC)
   sei(); // Enable the Global Interrupt Enable flag so that interrupts can be processed
   for (;;) // Loop forever
    PORTA=j;     // Do nothing - echoing is handled by the ISR instead of in the main loop
    _delay_ms(10);
    j++;
ISR(USART_RXC_vect)
   char ReceivedByte;
   ReceivedByte = UDR; // Fetch the received byte value into the variable "ByteReceived"
   UDR= ReceivedByte ; // Echo back the received byte back to the computer
   PORTB=i++;
Ismail
I'm not sure what you have done wrong but here is a code that works fine in mega8 or mega32
#include <avr/io.h>
#include <util/delay.h>
#define F_CPU 16000000
#define USART_BAUDRATE 19200
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
 char ReceivedByte;
ISR(USART_RXC_vect)
   UDR = ReceivedByte; // Echo back the received byte back to the computer
int main(void){
   UBRRH = (BAUD_PRESCALE >> 8);
   UCSRC |= (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1);
   sei();
    while(1)
Have you changed your uC from ATMEGA 2560 to ATMEGA32? Where is the new proteus schematic?
@alexan_e
Sir I checked the code you have give.. on hardware its working, but on Baud rate 1200, not on 19200
Ismail
How can it work with 1200 when the settings in my code set uart to 19200?
that is the funnest this happening whit me right now....
is there any role of prescaler in this??
Ismail
Have you used a 16MHz crystal?
Have you set in AVR studio project properties the frequency to 16000000?
How did you figure that the output is 1200baud and not 19200?
i am simulating it on Protues as well as on hardware...
i have a kit of at mega 32 which is made for student. i have burned the coding in it.
1st i have checked it on 19200 by hyper terminal... it was not communicating at all.
Then i start decreasing the Baud at 1200 i got the output correctly...
Ismail
@madhusuthanan
done the setting of properties by 16MHz...
at starting only...
" return 0"
Negative (No change)
hi
UBRRL & UBRRH set as 0x33 in the program. do these changes check it out.
Ismail
Then you are doing something wrong.
Did you set the AVR clock to 16MHz?
Did you change the virtual terminal baud rate to 19200?
Upload your schematic
i have up loaded it check it Sir
Ismail
  • as.rar
here is the hex file also
  • test7.rar
Your current setting is using internal RC 1MHZ
Change it to crystal so that the 16MHz apply and it will work fine
Alex
Reactions: ismbn
    ismbn
@ Alex
yippeeeeeeeeee its working nice in simulation..........
But............. what to do with hardware Sir...........
Ismail
The code is correct in proteus or in real hardware, if you have problem then it is a wrong setting.
You are using a 16MHz crystal, have you changes the AVR fuses from the default 1MHz internal RC to External crystal, if not the crystal is ignored
how to do this Sir..
i mean setting of fuse from 1MHz to 16MHz
