how to compare multiple voltages?
timedate
Member level 5
Member level 5
germany
Hi, all
I get several (4-16) DC output voltages, all ranging from 0-3.3v.
and I want to compared all these DC, and choose the highest one as the input signal of my next stage.
what kind of devices should I choose? I searched for "multiple voltage comparator" but found nothing.
Thanks
Use as example PIC18F45K22 (can work on 1,8V) which have 28 10-bit ADC channels, take values from channels, compare them and some output pin should switch some MOSFET DC channel on, and other channels turn off.
A peak detector could do what you want.
The capacitor automatically charges to whichever is the highest incoming volt level.
This method subtracts a diode drop from all incoming signals. Therefore you should add 0.7 to all of them beforehand, because signals below 0.7 V will get disregarded otherwise.
The transistor can be used to discharge the capacitor. Or install a medium resistance across it, to discharge it gradually.
