jayanthi.k
which feed is best for improving the performance of microstrip patch antenna?
which type of performance do u want to change?
as probe fed antennas usually have lower BW as compared to other feed techniques.
I am aware of the antenna design handbooks and different feed types, but was not aware that feed type changes the bandwidth. Can you give a technical reasoning or reference to support your statement? Balanis only mentioned proximity coupling feed as having larger bandwidth, but does not mention any difference in bandwidth between standard microstrip feed and probe feed.
