sam781
Full Member level 4
- Joined
- Oct 22, 2011
- Messages
- 212
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 1,298
- Activity points
- 2,757
Hi TahmidWhat exactly do you mean by "Modified SPWM"?
Hi sam
The maximum out put wave of each half cycle will given by voh=1/T*integral over Vs dt from zero up to ton . it means the out put amplitude depends on your modulation depth
The waveform in post #1 is just the opposite: Less accurate sine or in other words higher harmonic content. An advantage of the low switching frequency (fpwm = 15*fsine) is reduction of switching losses, it would be primarly meaningful for high power (>100 kW) inverters.I've chosen Modified SPWM to get a more accurate sine wave than conventional SPWM.
Hi againSinusoidal PWM signal can be generated easily using a microcontroller. Hence, we can avoid comparison between triangular wave and sine wave.
