grizedale
Advanced Member level 3
Hello,
I am routing a dense double sided PCB for a xenon flash lamp.
The pad which is attached to the output of the trigger coil has 6KV pulses on it.
Due to space constraints, this pad is just 1.2mm away from another pad which has 12V on it.
Will i suffer arcing between the pads?
