h.sharma
Junior Member level 3
- Joined
- Jun 16, 2012
- Messages
- 30
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,455
Hey, I have to convert this code to mikroc compiler. It is compiled successfully in mplab but it shows many errors in mikroc .
please help me..!!!
thanx in advance.
##############Here are the errors shown....############3
0 1139 Available RAM: 352 [bytes], Available ROM: 8192 [bytes]
0 126 All files Preprocessed in 94 ms
0 122 Compilation Started automotive sensors.c
26 315 Invalid expression automotive sensors.c
25 402 ; expected, but 'data' found automotive sensors.c
26 424 '}' expected ';' found automotive sensors.c
27 424 '}' expected '}' found automotive sensors.c
34 371 Specifier needed automotive sensors.c
34 396 Invalid declarator expected'(' or identifier automotive sensors.c
45 1503 Result is not defined in function: '' automotive sensors.c
54 396 Invalid declarator expected'(' or identifier automotive sensors.c
55 300 Syntax Error: ')' expected, but '=' found automotive sensors.c
55 402 ; expected, but '1' found automotive sensors.c
55 393 '' Identifier redefined automotive sensors.c
55 312 Internal error '' automotive sensors.c
0 102 Finished (with errors): 17 Jul 2012, 18:06:46 automotive sensors.mcppi
please help me..!!!
thanx in advance.
#define LCD PORTB
#define RS portd.f0
#define EN portd.f1
#define _XTAL_FREQ 4000000
void cmd(void);
void temp_sens();
void main(){
int j=0;
char ldg[12]=" Loading...";
TRISD=0X00;
PORTD=0X00;
TRISC=0X00;
TRISA=0XFF;
TRISB=0X00;
PORTD=0X00;
LCD_init();
for(j=0;j<=9;j++)
LCD=ldg[j];
data();
while(1){
speed();
temp_sens();
press_sens();
car_temp();
void LCD_init(){
LCD=0X38; //using5*8dots
cmd();
LCD=0X0C; //display ON
cmd();
LCD=0X01; //clear lcd//
cmd();
LCD=0X80; //intial cursor position//
cmd();
void cmd(void){
RS=0;
EN=1;
delay_us(100);
EN=0;
delay_us(100);
void data(void){
RS=1;
EN=1;
delay_us(100);
EN=0;
delay_us(100);
void temp_sens(){
ADCON0=0b00000101; //channel 1 AN0
ADCON1=0b11000000;
int ii=0,j=0;
float f;
char t[21]=" Coolant Temperature ",disp[2];
long h;
ADGO=1;
while(ADGO==1);
h=ADRESH;
h<<=8;
h|=ADRESL;
f = ((h*5.0)/1023)*100;
float2string(disp,f);
LCD=0X94; //3rd line cursor position
cmd();
for(j=0;j<=20;j++)
LCD=t[j];
data();
} LCD=0XD4; //4th line cursor position//
cmd();
while(disp[ii]!=0){
LCD=disp[ii];
data();
ii++;
ii=0;
void second(s){
for(i=0;i<=s;i++){
for(i=0;i<=10;i++){
delay_ms(100);
void float2string(char *str,float f)
int d=0,i=0,j=0; char *t;
d =(int)f;
while(d!=0)
j=d%10;
//cout<<j<<endl;
i++;
d-=j;
d/=10;
for(int m=i;m>0;m--)
str[m]=str[m-1];
str[0]=j+'0';
str[i]='.';
i++;
f=f-(float)((int)f);
f=f*100;
d=(int)f;
t = &str[i];
i=0;
while(d!=0)
j=d%10;
i++;
d-=j;
d/=10;
t[m]=t[m-1];
t[0]=j+'0';
void press_sens(){
ADCON0=0b00001101; //channel 2 AN1
ADCON1=0b11000000;
int ii=0;
float f;
char t[]=" Fuel(%) ",disp1[2];
long h;
ADGO=1;
while(ADGO==1);
h=ADRESH;
h<<=8;
h|=ADRESL;
f =100-(((h*5.0)/1023)/5)*100; //100-(% out of 5.0)
float2string(disp1,f);
// LCD=0X94; //intial cursor position//
// cmd();
for(j=0;j<=10;j++)
LCD=t[j];
data();
while(disp1[ii]!=0){
LCD=disp1[ii];
data();
ii++;
ii=0;
speed(){
int j=0,ii=0;
float f;
char t[]=" speed(rev/min) ",o[]="overdrive",disp[3];
TMR0=0X00;
//TOCS=1;
//TOSE=0;
//PSA=0;
OPTION_REG=0b00000001;
second(1);
f=60*TMR0; //REV/MIN
LCD_init();
for(j=0;j<=14;j++)
LCD=t[j];
data();
while(disp[ii]!=0){
LCD=disp[ii];
data();
ii++;
ii=0;
LCD=0XC0; //2nd line cursor position
cmd();
if(f>60){
for(j=0;j<=8;j++){
LCD=o[j];
data();
void car_temp(){
ADCON0=0b00010101; //channel 2 AN2
ADCON1=0b11000000;
int ii=0,f;
long h;
ADGO=1;
while(ADGO==1);
h=ADRESH;
h<<=8;
h|=ADRESL;
if(f>=25)
RD2=1;
else
RD2=0;
