kae_jolie
Full Member level 4
I have 5-element λ/2 dipoles spaced 0.1λ apart (they all show in the model...I am not using the Antenna Array Setup wizard). They are all excited with 1W each and the port impedance for each is 73ohms. After simulation, the power accepted is about half less than power incident. When simulating one half-wave dipole alone with 73ohms port impedance, the power accepted is about the same as the power incident which tells me the antenna is well-matched. When in array, the power accepted is about half less than power incident, which tells me that the rest of power incident is lost due to mutual coupling between adjacent antennas. So, is it safe to say that HFSS does automatically account for mutual coupling effects of adjacent excited array elements?
I actually matched each of the antennas using the re and im Active Z values provided by HFSS and got the power accepted to be close to power incident, but when I place a lossy dielectric near the matched array, I don't get as much absorption in the dielectric as when I place the non-matched array near the lossy dielectric? Anyone knows why? I am tempted to just go without the matched array which is actually good since there won't be a need for a matching network.
Thank you all.
Thank you all.
