elamparithi
Newbie level 5
Hi all,
How the Clock speed calculated from the delays like Clk-to-Q delay and other delays???
Hi all,
Two devices that each receive a clock input from the same signal will not receive that signal at precisely the same time. The difference between the arrival time of the 'clock' signal at those two devices is called clock skew. Now if you consider a whole bunch of devices that each receive the 'same' clock signal, the arrival times of that signal at each of those devices can be different. Take the latest arrival time of the clock at a device and subtract the arrival time of the clock at the earliest device and you have the maximum clock skew for any of the devices that receive that clock signal.Thanks KJ for the equation. What is called called clock skew maximum??
