What VDD and VSS means ???
AD76XYZ
Junior Member level 1
Some times I saw in circuit VDD and VSS, here VDD means positive and VSS means zero. What is the full form of these VDD and VSS.
And is there any this type of three letter word for negative voltage and ground?
Any one explain in detail.
The microcontrollers has lots of mosfets inside of them. To make run a mosfet you should apply some voltages to its pins.
Here a picture of mosfet.
Vdd= 'Voltage Drain Drain'
Vss='Voltage Source Source'
The Ground can be written in form of 'gnd'
    lucarlo
    Hi tusemo, I am looking for help. I am wondering if you can talk about this, do you have any number or mail? Thank you
tusemo's right and on schematics and much older chips you'll sometimes find VCC or Vcc used. This meant 'Voltage Collector Collector' in a former BJT dominated world full of NPN and PNP transistors.
The double terms ('Collector Collector' etc) refers to a connection to that terminal side of many transistors, not just one transistor as per Vd/Vs/Vc etc.
BJT--- FET---"Vxx" meaning
________________________________
Vcc---Vdd |Positive supply voltage |
Vee---Vss |Negative supply, ground|
__________|____________________|
Apparently this terminology originated in some way from the terminals of each type of transistor, and their common connections in logic circuits (i.e., Vcc is often applied to BJT collectors, Vee to BJT emitters, Vdd to FET drains, and Vss to FET sources). This notation then carries across to integrated circuits -- TTL ICs were originally based on BJT technology, and so often use the Vcc / Vee terminology; CMOS ICs are based on FET technology, and so often use the Vdd / Vss terminology.
Reactions: persibal
    persibal
    lucarlo
    Hi Sherazi I am looking for help. I am wondering if you can talk about this, do you have any number or mail? Thank you
Hello!
This replies only partly to the question. Why voltage drain drain and not voltage drain only?
Dora.
its because you can have voltage between base and emitter that is called Vbe and so on so voltage at collector with reference to gnd is called as Vcc, and so ON
http://www.jestineyong.com/what-is-vcc-vee-vbb-vdd-and-vss-stand-for/
Thanks, that link explains it nicely. I had been wondering about this as well.
According to the article:
They are all supply voltages. Vcc = Collector supply voltage, Vee = Emitter supply, Vbb= Base supply voltage, Vdd = Drain supply, Vss = source supply.
[snip]
Since there is no notion to identify ground (0) this method was simply adopted. The voltages can be negative or positive depending on the the device and the circuit configuration. This method is a standard specified by Institute Of Electrical And Electronics Engineer (IEEE).
Assuming that's true, it's got to be one of the silliest decisions the IEEE ever made, IMO. According to the "standard", both supply rails in the circuit below should be labeled "Vss".
It was probably decided before CMOS - with NMOS only processes. It could have been said that VSS could mean 'substrate' but the first processes I worked on had an N type substrate so that wouldn't apply so I guess 'source' makes sense.
Keith
It is nice to know about these terms. The link provided by sherazi is really nice and informative. Now I understand the things. Thanks for helping me.
Thanks.............
Here I labeled every voltages in a basic circuit. The reason why it is called Vdd inside of Vd, is to make a difference between them, because they refer to different voltages in the circuit.
tusemo
Hello!
tusemo
You're the first explaining why these double letters.
Thanks!
Dora.
