How to calculate width of metal that is between a pad and a block
Jushoraj
Member level 1
Member level 1
Bangalore
Assume a pad and a block is placed 1mm apart from each other. If they are connected together by metal M1 carrying a current of 100mA, What will be the width of M1.
I need the total solution. Can any one help me to solve this out?
Re: Analog layout: Solve
You can use the EM check tool in cadence and find out what should be the width required to carry 100mA through M1 of length L..
W = L*RA * I / Vdrop
W = width [µm]
L = length [µm]
RA = area-resistance [Ω/◻]
I = current [mA]
Vdrop = acceptable voltage drop [mV]
Your(?) example: L=1000µm ; RA(M1) ≈ 0.1[Ω/◻] ; I=100mA ; Vdrop = 100mV
W = ... = 1000 * 0.1 = 100µm
W = width [µm]
L = length [µm]
I = current [mA]
Really thank you for your reply......
