Using ports and Netalias?
iyan90007
Newbie level 6
Newbie level 6
Can i use ports instead of net alias inside the same page for connectivity. Will dat cause any troubles in my hierarchical design ???:?::?:
You can use ports within a sheet for connectivity but i have question, why you want to connect using ports?.
when using net alias even though it s connected i feel the wires are stranded. If i am using ports within my design i can easily view it. It is jus for the sake of readability and a feel of ease.
Thanks and Regards,
Iyan
Ports and Net lables , both are using for connection conectivity , not only with in the sheet it can connect multi sheets also, so no problem you can use any one.
Actually We use ports for sheet to sheet connectivity
net labels for connectivity within a sheet and also this can also be used for sheet to sheet connectivity if we set net identifier scope as global.
