jordan76
Full Member level 3
Hi guys,
Below is an excerpt from the handbook of National Semiconductor:
Could anyone explain the bold and underlined part in detail? Thanks.
regards,
jordan76
Driving Capacitive Loads (These hints apply to analog-output sensors).
National’s temperature sensor ICs are micropower circuits, and like most micropower circuits, they generally
have a limited ability to drive heavy capacitive loads. The LM34 and LM35, for example, can drive 50pF without
special precautions, while the LM45 can handle 500pF. .
If heavier capacitive loads are anticipated, it is easy to
isolate or decouple the load with a resistor; see Figure 4.5. Note that the series resistor will attenuate the output
signal unless the load resistance is very high. If this is a problem, you can improve the tolerance to capacitive
loading without increasing output resistance by using a series R-C damper from output to ground as
shown in Figure 4.5
Figure 4.5. Capacitive drive options. The LM34, LM35, and LM45 can drive large external capacitance if isolated
from the load capacitance with a resistor as in (a), or compensated with an R-C network as in (b).
The LM50 and LM60 have internal isolation resistances and can drive any value of capacitance with no stability
problems. Ensure that the load impedance is sufficiently high to avoid attenuation of the output signal.
regards,
jordan76
