[SOLVED] MCP23017 I2C I/O Expander Input Reading Problem
Jestin_cubetech
Advanced Member level 1
MCP23017 Input Reading Problem
MCP23017 I2C I/O Expander Input Reading Problem.
write PORTA  //it works fine
i2c_waitForIdle();
i2c_start();
i2c_write(MCP_WRITE); // Opcode write mode   MCP_WRITE=0x40
i2c_write(IODIRA); // set port A as outputs              IODIRA =  0x0
i2c_write(0x0);       //set port is output
i2c_stop();
i2c_waitForIdle();
i2c_start();
i2c_write(GPIOA); // set port A as outputs              GPIOA =  0x12
i2c_write(0x55);       //set output   0x55
i2c_stop();
              //Problem is Here!  PORTA Reading is not working.
i2c_waitForIdle();
i2c_start();
i2c_write(0xff);       //set port is input
i2c_stop();
i2c_waitForIdle();
i2c_start();
i2c_repStart();
i2c_write(MCP_READ); // Opcode read mode
i2c_write(GPIOA);
value=i2c_read(1);        //ACK
i2c_stop();
return value;
data output
input reading
Re: MCP23017 Input Reading Problem
___________Problem solved !__________
Read Sequence
i2c_waitForIdle();
i2c_start();
i2c_write(reg);
i2c_repStart();
value=i2c_read(0);  //ACK
i2c_stop();
return value;
Read Sequence
i2c_waitForIdle();
i2c_start();
i2c_write(reg);
i2c_repStart();
i2c_stop();
return value;
I'm having problem with reading continuously from the MCP using I2C, do you have any suggestions?
